When loading my new Equinox with splits in the E W direction thru the front door, you can really only get three good sized pieces in there. There is a ton of space left at either end but unless you have the right sized wood to slip in there, you are kinda stuck. The limiting dimension seems to be firebox height, plenty of width and depth but I don't want to force anything up against the burn tubes at the top of the box.
I'm considering either cutting next years wood short (16") or long (up to 24"). If I go short I can fill N S from front and not worry about wreastling long heavy pieces in from side door over a hot coal bed.
I'm not really complaining here as the three big splits (honey locust) I did shove in there last night at 10:00 pm burned with the damper set to low all night and at 7:00 am I had a vary nice coal bed that would have still been active at lunch time. We were in the mid 30's last night and were cruising at 72 inside.
Another issue I question is the floor temp. Before I added those overnight splits we were enjoying a higher heat setting maybe half throttle for a couple of hours until we got the house toasty. Just before I loaded for overnight I walked around the side and back of the stove and felt the floor. To hot to keep your hand on but not hot enough to burn. I have a tile hearth system over plywood subfloor, the installation is code compliant. Please comment on how hot your hearth gets.
