48" away from windows?
jzinckgra
268
Raymond, Maine
I used to have a pellet stove and am considering putting one in our downstairs. We have a woodstove upstairs already. My only option downstairs is to caddycorner the pellet stove, however there are two double hung windows on either side. One window is ~40" away from where the stove pipe would exit and the other is ~24". Both windows can be opened. I never really understood the code whereby you have to have 48" from windows that can open , since I'd never be opening the windows in winter anyways.
Have any of you violated this code? I'm guessing if we hire someone to do it, they may have an issue with the windows, but we live in a pretty rural area, and I'm sure the rules can be bent. Obviously I can understand the possibility of smoke coming into the windows if they are open, but we'd never open them, so..... If there are other safety consideration to this law, what are they?
One other question; how important is it to have a run of vertical pipe on a pellet stove install, versus a straight shot out the building. FWIW, I am looking at the Harman Accentra. Thanks.
They mean 4' for the exhaust to be away from the windows, not where the stove is to be placed. Look at my pics.
Pic 1 shows how close the stove is by the windows.
Pics 2 shows that the vent is MORE than 4' from the windows.
If you go straight out, you'll have little draft, in case of a power outage, smoke can return in the house. That's dangerous, especially if you have the unit on during sleep. Do something like I did and have peace of mind.
  • [Hearth.com] 48" away from windows?
Check your local code, sometimes a window lock is all that is necessary. Also, if you go up, you only have to be 1' above the window.
Makes sense. I guess I was hoping to vent the stove with less than a 48" space and not have to go to either the roofline or 1ft above the window. The latter is certainly feasible.
I needed to violate that code also for exactly the same reasons - Only way to possibly make it work. I have fairly new good sealing windows and have never had a problem. I also want to know what idiot would ever open their windows in the winter time right next to the stove. If your windows are good and tight, like mine, you shouldn't have a problem.
yeah, opening the windows in winter was my thought as well. Who does it, unless they aren't using an outdoor air kit maybe?
I got legal by adding a 2' section of vent pipe to the vent... made it 40-some inches from the window. My dealer also insisted I disable the window so it wouldn't open... as far as they know I did.
You still may be able to violate the 48" requirement if you add an outside air kit (OAK).
Most Harman units allow you to do this.
The OAK can let you be within 18" of a window....
Sawduster said:
......I also want to know what idiot would ever open their windows in the winter time right next to the stove........
I'm sure we could find some people that qualify for the "Darwin Award" in this situation....like they had to open the window "because the room was too hot!"
:shut:
Most Harman units aloow you to do this.
What does the OAK have to do with being able to locate the stove pipe closer to a window?
the stove creates a negative pressure environment in the house (without OAK). Theoretically this allows the stove to suck air into the house from the outside. At less than 48" you have to possibility to suck exhaust in through leaks or.....open window. The OAK defeats the negative pressure environment by sucking combustion air from outside, reducing the likelyhood of sucking exhaust gases in (even if the window is open), hence the 18" minimum with OAK.
Makes total sense, thanks. A guy is selling his Accentra with some pipe for $2K. It might be 3 years old, don't know yet, but is this a fair price?
Too much considering the Government tax credit of 30% on new stoves.
This guy keeps his windows closed %-P
His pipe is also too close to the house, and it doesn't look like he cleans his stove very often (or ever).
