Yes but bolted on the out side of the exhaust blower box instead of in the vent stream.Is that like the ESP probe in a Harman?
Interesting. It's good you were able to get some and keep them going. If it is a thermistor (which is like a Harman remote temperature probe) then it can be extended. It looks like they have used high temperature wire, but if you cut it before the plug it could be extended a bit.When US stove company bought Ashley Pellet stove out they change the board on the Ashley kp130 about 1 out of 10 stoves were programed wrong. They would not burn well and smoked heavily US stoves answer was to replace stove and just junked the bad ones. I bought 2 for "scrap" changed the control board sold them they are still running well. I just don't remember the thermistor being that short.
You need to have some type of non combustible material under the stove whether you buy a pad or build you own from tile/brick. Check your manual it will tell you the dimensions ie how far out on sides front and back.How crucial is it to have a floor pad under the stove, we have old oak flooring, not great looking.
I posted what I thought was your manual a few posts ago. It showed a microswitch wired to the auger circuit.I thought it was the hopper lid safety switch
Where is this water damage coming from. surface rust on the fan housing and corrosion on the manifold.You’re on the right track, once you have that loose setup off and inspected you’ll know what to purchase for your exhaust.
Is the maniford repairable or will it need to be replaced? Wondering if JB Weld would work in this situation? Any pic of the hole in the manifold?It was a pain to extract that manifold peice without removing the exh fan, so I'm sure they didn't do any of that
I don't know about those joints , they have felt seals, but the manifold lip that bolts to the fan outlet is definitelt bent.There’s a few areas of concern through your videos, are the areas I’ve circled sealed or?View attachment 341209View attachment 341210
I'm going to try hi temp rtv, lots of it.Is the maniford repairable or will it need to be replaced? Wondering if JB Weld would work in this situation? Any pic of the hole in the manifold?
so far its no parts required except rtv. I'll go ahead and order the fan housing gasket, it looks knackered.Are you going to test the stove "repaired" first before buying parts? There is a show on Utube called Vice Grip Mechanic. He would go and try and get old cars running to bring home. He always made sure to test them before putting money into them. A new blower assembly would be high on the list of new parts if it runs.
Thanks for that, even amazon sells the fan housing, living up in Maine I buy a lot of stuff from amazon.Hard to tell from pics and vid but the damage looks to be on the exhaust fan housing and not to the stove weldment. You can buy a new exhaust fan with the housing. You might find cheaper ones if you search around.
https://www.ebay.com/itm/388957657313?_skw=80473&itmmeta=01K85AJKXGW06A4VKCH2B9CXX4&hash=item5a8faed8e1:g:WfwAAeSwmlZow5uI&itmprp=enc:AQAKAAAA4FkggFvd1GGDu0w3yXCmi1dXW9qz1VZaJLrTPCS/MMUDpf7w4iXoXZ76T5ClLhokmDKCCkDPcIHDD5t/F4+HaVKFRrlImV/6GnQKOfY+SK1EdDeGp3GYKZOtlVNX21jfju3yoqh+TaFwEHOA0/YDTYVxcrq50silQVhYLjq6MvVJP8yO5qsfONExKNAj96/zkvt6B2aL+q65oe25MnePCAjEIjWwwp0UXlJ1QDTIGrYS3K3IqHQBKwYJFMWnxafWQoK0bMe6EHTdzSURGIpPVL4RKFQguQtr7ebcRCkldpwi|tkp:BFBMlr_KqsFm
https://pellethead.com/product/pell...ustion-blower-exhaust-fan-motor-with-housing/
https://pellet-stove-parts-4less.com/collections/us-stove-king-kp130/exhaust-system
https://www.walmart.com/ip/Mustrod-...XxuPKz0pjZuqxGylc8919x7pKG5AbJBxoCzDwQAvD_BwE
https://www.amazon.com/US-Stove-80473-Exhaust-Blower/dp/B004V7FP9Y
