we have and do use Pensotti, with good success. Hydronic alternatives has also been recommended to me by those in the know. on the east coast you will have lots of options. Here in the Midwest, not so much.So what are some reliable brands?
karl
Heating the floor is doable. My basement is open. I do have nails protruding down from the hardwood flooring. What's the best application for my scenario?
Been there... done that...
two options..
1. A hammer, bend them all over.
This tends not to work as well as one would expect so then there is option 2...
A ladder or better a Work Platform
a 90° grinder with a cutting disk
an old pair of coveralls (cotton or it melts)
a good face shield, (just safety glasses if you believe that chicks dig scars)
Advil.
be advised, cut nails... cut hard.. DAMHIK...
Had a chance to take one of the radiator in the girls' bedroom.Send me some pictures.
I'm going to be watching this as I have been thinking the same thing for one of my rooms.
After researching this further, it appears there are two major players in Europe. Quinn and Rettig. Myson, hydronic alt, pensotti, dianorm, purloined appear to be one of the two. If you look at the specs they're all pretty much the same. So I'm looking for bang for the buck. Runtal seems expensive in comparison.
I think over sizing it it the way to go. If I'm able to plumb this to receive the return water from my other zones, that could be an added benefit. Haven't figured out the how yet. It looks as though going to a much larger configuration gives the room heat at higher temps as well as continued heating at lower temps. I could always add trenching or radiant if this isn't sufficient. Most Europeans with gassers use radiators.
Thanks. So figuring I want have consistent water flow @ 180 but rather 160s the btu drop off. So over sizing would probably yield the consistent 70° heat in the room.
