Adjustable vent bracket/standoff?
P38X2
1,670
Jaffrey, NH
I'm thinking of adding a vertical section to my vent pipe. Right now it's straight out. The stove burns fine, but since upgrading to a P68 (from a 38) I'm getting a bit more smoke in my house during scrapings than I'd like. Hopefully more draft will solve the problem.
My question is does anyone make an adjustable bracket? If I remove the horizontal section that passes through the thimble and replace it with a shorter piece in order to get the pipe closer to the wall, it's likely not gonna end up exactly where it needs to be. Moving the stove in or out is NOT an option, so I'd need a bracket that has some adjustability to it.
I suppose I could cannibalize a bracket and add or remove material, but looking for a less customized approach.
Reactions: DBCOOPER
Something like this? @ (broken link removed)
[Hearth.com] Adjustable vent bracket/standoff?[Hearth.com] Adjustable vent bracket/standoff?
DuraVent 3PVP-WSA
3 Inch Pellet Chimney Adjustable Wall Strap
  • Our Price: $21.99
  • You Save: 10%
Qty:
Yes, thanks for the info :)
I have a similar problem. the adjustable bracket shown above ((broken link removed to http://www.woodlanddirect.com/PelletVent-Pro-Adjustable-Wall-Strap_2?gclid=COrOrMffkrwCFclQOgodsikAJg?gdftrk=gdfV23673_a_7c1677_a_7c8224_a_7c2591790_a2s__a3a__a2s_2591791#259Diameter%3A3%22)) only provides 1-3 inches of clearance. What if I need to go beyond 3 inches of clearance...let's say 4-5 in? is there a product out there for that? Or would I need to cut/trim a vent pipes to get to the perfect length?
You can easily add a piece of aluminum between the two pieces of the bracket. Two cuts with a dremel and four drilled holes for the bolts on each side and you will be good to go. Probably five dollars at home depot or Lowes. I will try to take a picture of how I did mine later.
Reactions: PennPellet
Thanks, a picture would be great.
Here is what I did. Just cut a piece of aluminum to size for each side and then drilled holes to attach the bolts. Takes maybe ten minutes if you have a dremel (doesn't everybody who has a pellet stove?).
I just put a piece of red cedar 2x4 against my siding and screwed into that to give myself a little more clearance.
Excellent, that's exactly what i wanted to see. Thanks for the help!
Excell has an adjustable bracket. Adjusts from 1" to 5"
(broken link removed to http://www.stoves-pipes.com/ICC-EXCEL-PELLET-3-4-ADJUSTABLE-WALL-SUPPORT-p/pmpsw.htm)
There is also the possibility of using a variable length vent section. I think that Duravent makes an adjustable 12" section.
Pretty sure the adjustable section is only meant for vertical portions of the vent. It also won't fit through the duravent thimble. Even if you were able to get it to fit you would have to be careful to not get the seam in the wall space.
I went through the same thing, ended up having to use a two foot section of horizontal out the wall (wall is almost 12 inches thick).
Thanks for the responses. I back burnered the reconfiguration, at least til spring. At this point, I simply do my pot scrapes during maintenance burn time. I wanna keep it clean looking on the outside, and I have my doubts that adding a 3' section would do much.
Reactions: jdinny
I agree. I was going to do the 3" vertical rise, but decided against it.
That plus the fact I'd have to add another 90 before the cap. I don't know exactly what 90's do to the EVL, but my guess is it would decrease and draft gained by the 3' section by half.
It's all good how it is now.
