affordable DIY spray foam
EatenByLimestone
Moderator
Staff member
Company is Foam it Green
sprayfoamkit.com
I tried to paste the link but it wouldn't work... passive aggressive phone...
It looks less expensive than the Dow Froth packs.
i own a sprayfoam business and they are charging more per board foot than I charge to come in and do it for you with professional equipment. Almost 1.20 per board foot and you still have to do the prep and clean up..... I charge generally around 1.00 or even less for a bigger job. That's with my guys and myself doing all the work.
When I lasted looked into the cost of DIY foam it was very expensive per volume of foam produced (board-ft).
I know it was much more expensive than board foam and I believe even more expensive than the small single use cans (Great Stuff).
I was going to look into a froth pak type foaming kit, but after reading this I will contact a local company. If they can give a better break and do the work, why not.
