Alderlea T5/T6 Calculus
Pechka
Hi wood burners, looking for some input from the more experienced
I'm considering installing the Alderlea T5/T6 into a new ~2000 sq ft house in the Lower Mainland, BC, Canada
Im still on the fence deciding exactly which model to go for though T5 or the bigger T6.
Reading the specs online it doesnt quite make sense to me the way manufacturers spec the heating capacity in sq ft - since we're heating volumes and not areas I'd expect cu ft makes much more sense. Turns out the assumption here is a standard ceiling height of 8ft and the areas are provided for ease of calculation, however this can be misleading for non standard/square living spaces, such as mine. Using a 8ft standard height the calculated heating capacity for the two models in cu ft are:
T5 => 2000 sq ft x 8ft = 16,000 cu ft
T6 => 3000 sq ft x 8ft = 24,000 cu ft
I also calculated the exact volume of my house from the info in the arch dwgs taking into account the shape of the living space and ignoring the internal walls and furniture in came up to 20,000 cu ft, which interestingly happens to be right in the middle of the two stoves heating capacities. I'd therefore conclude that the T5 would be undersized for my space by exactly the same amount as the T6 would be oversized.
In conclusion Im thinking if i get the T6 model and damp it down to 83% of it's stated capacity it would adequately heat my entire house with the help of the ceiling and furnace fans to circulate the air.
0.83333 x 24,000 = 20,000 cu ft
Does all of the above make sense to you? or am I overdoing it or missing something?
Another factor into consideration would be that I intend to primarily burn local softwood species in the stove which burn faster and hotter and therefore would be able to reach the optimum temperatures even with partial/smaller loads
It would be nice to have a bigger firebox and longer burn times with the T6, the only downside i see is potentially more frequent chimney cleanings required due to suboptimal burn rates.
Any feedback greatly appreciated - this is going to cost upwards of 10k Canadian pesos, so Im hoping to get it right the first time
Thanks in advance!
PS> forgot to mention some additional tech data in case relevant:
- wall insulation R24, 2x6 studs
- ceiling insulation R40 or R56
- heat loss as per the energy report of 25000 btu/hour, assuming inside temp 22deg celsius, outside temp -9 deg celsius
- additional heat sources: gas furnace and heat pump
- planning on mostly using the wood stove when the temps dip below 5-10deg celcius
- relatively mild climate, but very wet, temps are mostly 2-5 deg celsius for most of the winter, occasional cold periods of -10, -15 but they dont last more than a week or two per year
Thanks in advance!
Probably the biggest factor will be where the stove is located and how well you can get the heat out of the that room. You can't assume that the furnace blower or ceiling fan is going to move all the heat out. I'd be going with the smaller one unless you were in an open concept log cabin. Also, It does not get that cold where you are. (I lived in Kits for 5 years). Tell us about the room and the layout of the house.
Heat load isn't calculated by volume either. If you really want precise numbers you'll have to do a manual J for your house.
But with that said, the heat output of a wood stove is not constant, so you'll need to balance your priorities in terms of how much temperature swing you can tolerate vs. how often you want to reload the thing among other considerations. You can build a small fire in a large stove but not vice versa.
I’ve never heard it disclosed where that 2000 sq ft house discussed in the literature is located. Every manufacturer seems to refer to it though. Some of the users, after buying a stove believe it’s located in South Florida due to the amount of heat the stove puts off. Fewer think that house is in northern Wisconsin.
Reactions: Burnin Since 1991
Hey ya your right. Why do they even bother? They give the max BTU output so why the house sq ft? If you can't get the heat
out of the room, and are over heating the room, you are going to have to let it go out.
Get the T6.
Thanks in advance!
Thanks for the detailed specs. That helps a lot. A new tight house with great insulation is not going to need a ton of extra heat unless there is an extra large amount of windows. What is the floorplan like? One story or two? Open or with rooms closed off?
My suspicion is that the T5 is a better fit, especially if this is for occasional use. It still has a good long burntime in a N/S loader. If the heatpump is sized properly and a hyperheat unit, it should be able to easily heat the house at -9ºC. A 3 ton Mitsubishi hyperheat is able to put out 36,000 BTU/hr at that temperature and guaranteed to heat well down to -25 C.
Thanks everyone for the responses, I followed the most comprehensive one from Highbeam and ordered the T6 :)
Will report on it's performance down the road.
I asked Google/chatGPT to report on the average winter temperatures in my area and turns out I was pretty close on 2degC. Kits is right on the ocean and it's a bit milder there, Im on higher ground at the boundary between Mission and Maple Ridge.
For the floor plan imagine a rectangle 66'x18', the kitchen area where the stove is gonna go is 18x18, open space to second floor and a huge glass side (windows and glass doors) all the way to the ceiling. Second floor is a hole to below then another 33' of open space, no wall and then a small room at the far side. Like I mentioned in my original post I'll have a big 72in ceiling fan in the middle of the kitchen area to move the air in addition to the furnace fan.
That's what the salesman said, of course he won't stop me from spending more money on the more expensive model
...especially if this is for occasional use.
Actually I wanted to size it so it does not rely on supplementary heat sources - think of this as an emergency or independent heat source. And depending on how it goes I may very well use it as a primary heating source when there's more than 15+ deg temp differential
Both my heatpump and gas furnace should be perfectly capable of heating the house independently, so many ppl in my place would skip the wood stove altogether, but I'd like to have one - where i grew up my grandparents had a wood/coal stove and nothing beats this form of heating imo
Finally a quick question re the firebox size on the T6 - can any T6 owners provide dimensions pls? not just the volume, but actual dimensions of the firebox. Even ChatGPT doesn't know this one and it's not in the specs either for some reason, they just report the 3.0 cu ft volume
