Ok, I have a home that is all electric. by all electric I mean that my heaters are all forced air heaters (Cadet). I have no furnace of any kind. In our basement (which we are finishing), there is a 6 inch pipe opening in the chimney where the old gas furnace used to vent. We have a fireplace on the main floor that also ties into this chimney. I checked the chimney with smoke pellets from the basement and it gets good draw from down there. I am considering installing a large (big enough to heat 2500 sq ft.) wood burning furnace in the basement and attaching it to that chimney vent. All my old duct work was removed due to its size, so I need to re-install new duct work. My questions are as follows: Since I have low ceilings and want to put in drop in ceilings, can I make (or have made) thinner more streamline duct work to use in the basement? Also, since I do not have an existing furnace, do I still need to have the return registers on the main floor to use with the wood furnace (one of the returns is in the middle of a patio door and I'd really like to eliminate it if possible)? I am basically just wanting to heat the basement and then supplement the electric heaters on the main floor by blowing heat up through the ducts. I still have all my floor registers upstairs. Any other things I am missing, problems, etc...? Thanks in advance for the help.
