I have been toying with the idea of building an insulated surround and block of plate for my insert to increase heat output to the house (versus heating the large fireplace chimney).
I have done quite a bit of reading about the topic and have seen where people have used durarock or Micore for casement boards with Roxul wool insulation between the boards and the fireplace walls.
My local store does not have Micore and they recommended I use Alurra Fiber Cement Board. I want to make sure that would be ok in lieu of Durarock or Micore.
www.menards.com
That is a link to the product at my local Menards that I was looking to use.
Thoughts?
Allura™ 1/4 x 3' x 5' Fiber Cement Underlayment
This Fiber Cement underlayment is installed over the subfloor to provide a smooth, water-resistant, durable surface in which porcelain or ceramic tile may be installed. It may also be installed for countertops in conjunction with tile. These products feature a dense, non-porous surface making...
Thoughts?
