- Aug 20, 2007
- 644
<div class="bbWrapper">I was reading Highbeam's recent thread on his install using Duravent DVL and his trouble with the damper/adapter section. I used the exact same setup to vent a Napolean 1150p - adapter/damper section directly on the stove's top vent section, followed by telescoping section, right into ceiling support box.<br />
<br />
My question is on the adapter/damper section. I believe that the instructions detailed installing it with the tapered end of the adapter INSIDE of the collar/vent on the stove - this is correct, right? When mounted on the Napolean, the adapter does not fit all the way down so that it's flush with the stove top. The height of the collar/vent on the stove does not allow for it. I simply shoved the adapter/damper section on as far as it would go - seemed tight - no side-to-side play like Highbeam described. I burned last winter without any problems, but reading Highbeam's thread got me paranoid and I wanted to make sure I installed correctly. <br />
<br />
Also, for what it's worth, I did use the screws in the middle of the telescoping section and do get cracking/pinging noises on heat up and cool down sometimes.</div>
