First time poster after reading dozens and dozens of threads here, so while I appreciate your willingness to help, I'm not looking for general advice, but hoping I can hit some of the Harman owners who have been through this themselves.
For example LeafMold's nearly saved me with this post https://www.hearth.com/talk/threads/might-have-solved-my-p68-burn-problems.32676/ because my does indeed have those (clogged) ports, and a bit of coat hanger and air can cleared out the channels.
The story
I have an older harman xxv (~2003 i think) that burned great when I first moved in, and after ~2 tons is burning sooty, lazy, tall flames, smokey output. The burn pot eventually fills with under-burned buildup, the stuff of klinkers but just filling the burn pot.
Some obvious things I have done, mostly regular maintenance
- full clean, inlet, vent brushed and inspected
- combustion motor removed, cleaned
- full chamber clean (firepot, igniter, ash pan, scraped, banged and vaccuumed
And it really made no difference, virtually none.
Some additional maintenance afterwards
- replaced door gasket (now tightly holds slip of paper)
- replaced ash pan gasket - (what a PITA that was with those darn little screws)
Still garbage fire
Where I am now
Now I have a flame that is _better_, but not good. I can indeed now see almost a vortex where the ports above were cleared out, and it seems to keep the fire aggressive/bright for time after ignition, but then the flame starts to drift down, around, over all over and get lazy again filling the chamber with dull flames and soot.
Draft measures at ~-.38" which seems low (thats what manual reserves as maintenance mode, with full firebeing -.5 -.6)
So I'm thinking I finally need to replace the motor, but wondering if anyone else with a harman had something else. I do appreciate general advice but after spending a few weeks on this forum do think its make/model specific "quirk".
I grabbed some pictures of what low fire looks like just a week after my last full clean, and about ~30 minutes after scarping the pot.
https://photos.google.com/album/AF1QipNf3Fr2Zgzrm17XHypCAGRI5nsEURH2R30dWbAI
The story
Still garbage fire
Where I am now
![[Hearth.com] Another Harman woe about low draft and lazy flames [Hearth.com] Another Harman woe about low draft and lazy flames](https://www.hearth.com/talk/data/attachments/256/256903-e7467ea8c469189774439ba6f557c8f1.jpg?hash=8DwtEidIHD)
![[Hearth.com] Another Harman woe about low draft and lazy flames [Hearth.com] Another Harman woe about low draft and lazy flames](https://www.hearth.com/talk/data/attachments/256/256904-7890505f0f3769da5fba3eee436b34f1.jpg?hash=m1_wP5fYgq)
