Hi, I'm new to the world of wood stove inserts. I have a 1-1/2 story cape 1,700 sq-ft house in the Albany, NY area. The ceilings are about 7 ft high. The 1st floor is fairly open. The living and dining rooms are basically one room, 25 X 30 ft with the stairway to the upstairs in the center of the room. Air can flow around the stairway easily from the living room to the dining area. The existing fireplace is at the south end of the house, in the living room. The kitchen and mud room are at the other end of the house. You can stand in the mud room (north end of house) and easily see all the way to the south wall. Lot of spaces for air to circulate. The two 25 X 25 ft bedrooms and full bath are upstairs. The fireplace is masonary and contains a "heatalator" insert that has glass doors. The internal dimensions are: Width 41" in front 31" in back (trapezoidal); 29" high; and 24" deep. My plan is to use my current oil burner (hot water system) to maintain the house at 60 degrees and use the insert for temps upto 70 degrees.
I went looking for stoves on Thursday and the two stove inserts that were recommended by the sales persons (different stores) were the Country Legacy C260 and the Quadrafire 3100i. The heating area size for the stove are about equal 1,300-2,000 sq-ft. Installed with blowers, chimney liner, and tax prices were $4,155 (3100i) and $4,860 (C260), a $700 difference.
I have a two-acre wood lot with sugar maple, white ash, red oak, and hemlock. I figure that made the decision for wood over a pellet stove.
The max heat output of the C260 is 79,000BTU/hr and 10,000-54,000 for the 3100i. Should I put any creedence in those numbers? Or are they just sales numbers. The c260 weighs about 160 lbs more than the 3100i. The stove extension into the hearth are 7"(3100i) and 6-1/2" (c260).
So,
1. Does the insert sizing for my house seem reasonable?
2. Is there a concensus that the stoves are about equal?
3. Is there another stove insert that considerably better given my heating requirements? I looked at the 4100i but wasn't impressed with the door handle and the bay door itself.
Thanks for any input and I hope you had a fun 4th
Tim
So,
Tim
