Manual says that the cat can be engaged when the stt reaches 250 and that the intake should be 1 or less when in cat mode.
When I engage in the 250 range I do not get reburn, stove continues to idle. I need to have the stt in the range of 350 in order to get the cat to start to glow. I know my wood supply is less than great and moisture levels are all over the place, could excess moisture account for the need for higher temps?
Also, should I be throttling back the draft before or after I engage the cat? I've had mixed results with both ways...
Thanks
Thanks
