In the process of looking for an exhaust leak on my older model j1000 I decided to change out the ceramic blanket on the exhaust blower.
Well its turned into a huge ordeal because the exhaust fan blade was so crusted up with soot that I had a very difficult time getting it off. I ended up damaging the motor getting it apart. I blew the top part of the bearing retainer out of the cframe motor. I have put it back together with some JB weld and its back working again. But I thought this would be a good time to go ahead and change out the whole motor anyway. A replacement motor from Jamestown is $200 and a whole blower will cost me more than I paid for the complete stove! So I would prefer to find an aftermarket part.
The motor did not have any specs on it but I found these specs from another post on this forum with a similar year stove.
115V 60hz 25mhp cont duty
1PH Class B 3100 RPM .8AMP
I went to the local Graingers and they recommended this replacement motor.
http://www.grainger.com/Grainger/DAYTON-CFrame-Motor-5M065?Pid=search
It bolted up and was almost an exact match for everything. When I started it up though it would run for a few minutes and get hot and shut off. I returned the motor. They said it could be a bad motor but it also may not be getting the correct power input. I am not sure.
Any ideas on a good replacement for this motor?
