Any thermometer and moisture meter recommendations?
RORY12553
510
Southern NY
As the posting says any thermometer and moisture meter recommendations? I currently have 3 rutland thermometers that i bought at home depot. two on top of the stove which give me two different readings and one on the flue pipe which i have no clue about if it is accurate. also want a moisture meter to test wood in different areas of the stacks. seems towards the bottom of the stacks are little less seasoned then top and middle. possibly have to raise it off the ground more.
Any suggestions would be great.
Thanks!
Thanks!
General Tools MMD4E Digital Moisture Meter by General Tools $29.98 at Amazon
this works for me
[Hearth.com] Any thermometer and moisture meter recommendations?
BAFX Products (TM) - Non Contact - Infrared (IR) Thermometer (-58F - +1,022F!) - BATTERY INCLUDED! by BAFX Products $23.99
this works well too
I use this Tempoint flue gas probe for both stoves,,can be calibrated in boiling water and the needle adjusted...Part of an oil burner test kit. Part # 12-7014...Usually list for 100 dollars but one company sells them for $68.95...
[Hearth.com] Any thermometer and moisture meter recommendations?[Hearth.com] Any thermometer and moisture meter recommendations?[Hearth.com] Any thermometer and moisture meter recommendations?
