I have a Lopi pellet stove that is vented straight up through about 10’ of Duravent piping. It comes out of the stove into an appliance adapter, then into a tee with a clean out at about a 45 degree angle and then straight up.
My problem is that I find that the easiest way to fully clean the stove after each ton of pellets is to pull off the whole pipe assembly, appliance adapter and all and then clean the piping with my brush and clean inside the back of the stove all the way up into the outlet of the exhaust blower.
Is there some sort of compression fitting for that appliance adapter so I don’t have to caulk that joint? I currently use high heat tape and cut and redo each time.
Thanks for any help.
