Approximately how hot does the surrounding air in an existing firebox get when you put in a gas insert that puts out 24,000 BTU ?
karmicgumbo
3
Newland, NC
I am putting in a Napoleon Inspiration ZC gas insert into my old existing masonry fireplace. I need to build a custom surround for it to work, and will have to have some materials going into the space surrounding the insert. I am wondering how hot the air that is around the insert will get?
thanks,
D
thanks,
D
The installation manual for your specific model should have a section on this. The HeatnGlo inserts that I install require that all of the material used to build it out have to be non combustible.
Thanks for your reply. I understand it has to noncombustible, but even with the HeatnGlo's that you install, what temperature would the air surrounding the insert likely get to? I just have no idea.
David
Are you asking because you are going to not comply with the clearance specifications in the manual?
Or you will comply (in which case the answer to your question won't matter, but may satisfy personal curiosity...)?
Reactions: bholler
It is more of a personal curiosity about the physics involved with these devices.
thanks,
David
In that case install it and get an ir thermometer to play with
David
I don't know about your insert but here is a page from the install manual for a 40,000 btu direct vent fireplace.
I.R. does surfaces, right? He wants air temperature. Wouldn't a dual-probe bbq thermometer be better than an i.r. one for a test?
My Thermoworks dual-probe bbq thermometer would work well.
