Are self-adhesive gaskets any good?
SwampLife
37
Mojave Desert
I'm deciding between a self-adhesive gasket or a regular gasket. I can't imagine self-adhesive holds up as well?
Is glue better for standard gaskets or high-temperature silicone?
I've never installed a gasket before.
[Hearth.com] Are self-adhesive gaskets any good?
It depends on where it is used a gasket held in place by other means eg clips or a cover
of some sort can be a bear to keep in place as you put all the parts back together.
If a self-sticking gasket is used you don't have to worry about it not being in place as you reassamble.
Everything has its place and I use what is necessary to get the job done
Thanks. As per the photo, it's part of a Jamestown J1000 venting assembly.
So it is bolted to a matting part. Then self-sticking would work fine
They make a specific glue for stove gaskets. I like to use the glue better as it gives you time to reposition gasket if needed.
Reactions: Washed-Up
