Ashford 30.2 install thread
I’m probably wrapping burning up for this year I wanted to really pull the cat to inspect further and inspect my chimney, needless to say cat was worse than I thought almost fell apart pulling it out. And when I got to the chimney I was even less thrilled to see the build up it has caused. I’m unsure if that’s gonna come clean. Picture is looking up from clean out tee. I forgot to reach out to dealer as work was crazy busy with cold weather but plan to reach out tomorrow.
[Hearth.com] Ashford 30.2 install thread[Hearth.com] Ashford 30.2 install thread[Hearth.com] Ashford 30.2 install thread
Ugh, that's not a pretty sight. Is it from the bottom looking up, or top down?
How many hours or years on the cat?
Reactions: Highbeam
Something is not right if the cat was new. It should last around 10-12,000 hrs.
Reactions: Tron
Yeah I know. I’m under the assumption it was just a bad cat. I never even experienced the overactive new cat syndrome everyone has when the cat thermometer pegs. Plus I was pretty underwhelmed with heat output. So hopefully that was just the case. I’ll contact the dealer and get a warranty cat and probably get it installed and maybe I’ll do a couple day test run to see the difference before the season is over.
Reactions: bigealta
Why are they falling apart and getting all deformed? Remember the diesel foil cats? Those things got picked on for deforming like this.
That cat should have not been worn out in such a short time period but it sounds like you never got the cat meter very high and that flue looks pretty gooey as though the fire was never very hot either. Even without a cat, your flue should have looked better than that if you were burning at reasonably high temperatures with good fuel.
Reactions: stoveliker
Wish we could get an answer. It seems to be a trend and those who had the issue are having to use their one warranty replacement on defective cats.
Was always burned per manual burned on high after reloads and never engaged cat unless was into active zone. The point of the bk is to be able to stretch the burns to match heating needs If I wanted to burn on high all the time I would have gotten a regular secondary stove. Unless it was pretty mild the thermostat would usually be set around 4-5 o’clock after turning down from high on reloads. Max moisture I ever read randomly checking splits was 20.5. Which was one piece everything else was 17-20
That all sounds good but your flue shows some pretty cold looking deposits. A good working cat in the active range shouldn't do that.
I get burning low, that's how I use mine too. It spends 95% of the time on a very low burn rate but the cat is very hot.
Given how uniform the coating is, that would have to be the cleanout that's leaking in.
I've had a leak (where my stove pipe connects to the piece that goes through the concrete wall) and it's very clear where the leak is when you take a look inside.
lol that’s my whole point . It shouldn’t do that running in the active zone but it managed to do it. Which is why I think it was just a bad cat. But I only caught the cat problem the first day of February so it’s possible it was like that a bit longer letting a lot of unburned gasses through for a while, perhaps a couple weeks or maybe even a month idk I can’t say. They are processing my warranty so maybe I’ll have the cat by next week we will see
Lets hope that the new cat makes a big difference. Also, running with the cat meter "barely" in the active range is too low in my experience. You are too close to a stall. This leads to creosote accumulation because the cat is sorta active and you're just not sending enough heat up the stack. Be sure the cat meter stays quite high in the range.
I'm also concerned about the physical destruction of that cat. Hoping that the new one holds up a whole lot better.
We just don't hear about bad cats but operator error is very common. Maybe you just got a bad cat.
Finally got around to picking up the warranty cat and cleaning out the stove and cleaned my chimney as well. Wasn’t as much buildup as I thought there was going to be. Although I pulled the clean out cap a few times during the summer to check how much would flake off in the warm weather I’d say all and all I probably total had a half a coffee can to a full can of buildup with the old cat like that. All I can say is I better get 3 years out of this one. I’m also really hoping the heat output is going to be improved with this cat as I was pretty underwhelmed with the stove last season based off of what I read from other owners reports. I’m also hoping to catch back up on wood to get 2 years ahead but we will see
You're not two years ahead? Since you're in PA I figured you would be burning something like red oak that requires more than two years to season. I wonder if wet wood is why you aren't getting satisfactory performance.
Reactions: bigealta
yup
Low heat = wet wood
Creosote = wet wood,
Poor performance of wood stove = wet wood.
No just a little over a year. We moved here in 2020 so it’s been a struggle to catch up especially when we moved we had a under 1 year old then added a 3rd child in 2022. So it’s been busy especially with other projects to get done. Since almost the whole house was wallpaper when we moved in. But I’ve been trying to stick to ash since ash logs have been plentiful the past few years. But I think over this fall/winter I’ll get back to 2 years ahead. Also looking to add a woodshed instead of racks and tarps.
Burning in CT, I found with tarps and pallets, I really wasn't able to get Oak dry enough to where i was happy with it. Maple yes, but Oak was a real SOB to get good and dry. Shed/pole barn is where it's at for drying Oak.
Yeah that’s why I’m thinking shed as it seems like the ash log supply is dwindling slowly. Probably going to add an extension off the chicken coop with a place to stash the log splitter then be able to hold about 4 cords since it seems like about 2 cords is what I go through for the most part for the winter.
Reactions: tabner
