I have a condor probe in black pipe,and if I run the t-stat at 2.5 or lower after a few hrs. my condor says the stack is to cold. What am I doing wrong shouldn't I be able to run lower then that w/out a problem? The cat is active.
I have 16' chimney with 2 45's I don't have a stove top gauge but the cat is well into the active range.
So you don't think I will be creating creosote at 300?
Low stack temps are typical Blaze King. I don't have a probe, but I can hold my hand on the double wall pipe unless it is really cranking. If the cat is active and there isn't smoke pouring out of the pipe, I don't worry. I run my thermostat all the way closed in shoulder seasons. Think about all the heat you aren't wasting up the chimney.
A stove top thermo isn't going to tell you much on the jacketed Ashford. The firebox is under the cast iron top.
As with any new setup, check your chimney often, like once a month or so, until you get a feel for how you're doing.
Burn on.
The stove top temp & pipe temp will not give an accurate prediction, what does he have left?
outside 78
inside t-stat at 2.5 still a lot of wood left in her. Cat is still active and stack probe at 300
. Coming from a smoke dragon this thing blows my mind in my old fireplace this load would have been gone in 3 hrs.Sorry fell asleep on you it was a full load started at 5pm last night its 8am 40outside 78
Isn't it great! I love how clean the glass stays on it too! Ashford did a great job with the air wash design.
I think I have commented on this previously, but here goes. Condar pipe thermometers are mostly for single wall pipe. If you place the magnetic type (without probe) on double wall pipe, you'll get a far different reading that the actual flue temp.I have a condor probe in black pipe,and if I run the t-stat at 2.5 or lower after a few hrs. my condor says the stack is to cold. What am I doing wrong shouldn't I be able to run lower then that w/out a problem? The cat is active.
On average, it's the cleanest glass of any stove I've used. Most of my others would dirty up the glass most of the time unless I could run on high for a while. That's hard to do in the shoulder seasons.Your glass stays clean? Mine turns black. What gives?
