Hello all,I am new here but looks like a very informative place.Hope you guys can help me.I just got a Ashley King pellet stove from my aunt.Its an 09 stove model 5500m.She was second owner and didn't use it but once and the guy that bought it new only used it one winter. I gave it a good cleaning when I got it yesterday.Blew out the squirrel cage blower and everything. I have two questions.I lit it for the first time last night,I have it in my 24'x43' garage.It lit good and then I noticed before the room blower kicked on the other fan that was blowing steady while it was lighting started kicking on and off.Even after the room blower kicked on it still just kicks on and off.You can go outside and listen to the exhaust pipe and it kicks on and off..Is this normal? Doesn't say anything in the manual except something about it adjusting for the heat setting.I thought it would just blow more or less but maby this is normal.I have looked and looked on line and seen several complaints about this and seen a couple that said that's the way there suppose to do. Is this normal on this model? Second question is the rope gasket on door seal looks fine but when door is closed I can see a small gap at the top of the door.I can slip a piece of paper in one spot at the top of door.Should I replace rope gasket and can this be done by me?Does it glue in? Any help on these issues would be greatly appreciated.
