Auber AT100 cat probe length for Dauntless?
newguyjoe
119
Monroe,NY
Hi guys,
Is this the corretct Temp probe ?
This is what i orderd -
1 ea.High temperature thermometer, Pyrometer, AC powered (AT100TC)
  • Sensor Options - 6" (150mm) Inconel Probe
Thanks !
Joe
It's correct for a flue probe in 6" stovepipe. Is that where the probe will be installed?
No, i got it for the Catalyst. wrong ?
For the catalyst it needs to be a K type thermocouple.
And of the correct length for the Dauntless. Moving this to the VC forum for a more target specific response.
What auber part number probe do i order ? WRNK-171 ?
If you haven't drilled a hole in your Dauntless yet, the factory probe says to drill a 3/16 hole, but the Auber probe is 4mm, or roughly 5/32. I ended up drilling a 11/64 hole for a more snug fit. I haven't had any issues with thermal expansion of the probe and it still moves freely even when temps are above 1000 degrees.
Reactions: a59cheffy
Did you install the probe and attach it to the original bracket? I just bought the AT100TC with the 6" probe. I did not order my stove with the bi-metal thermometer or bracket.
I had to make my own bracket. I used a 3/4" pipe bracket. It took a little thinking to figure out the angle to make sure it went in straight. I used a piece of a cereal box to make a template for where the holes are drilled in the heat shield. Then I used a feeler gauge I had that had a pivot point to get the correct 90 degree angle. I measured that angle where the heat shield meets the shield around the bypass handle. and bent the bracket to match that angle.
