I am working on installing a Fisher Baby Bear wood stove into an old outbuilding approx 10'x11' with no insulation, open studs, no ceiling or wood roof sheeting only metal roof over the rafters. I assume I will need support for the flue at the ceiling height and at the roof exit. The stove exhaust is out the back so I'm thinking a 90 degree elbow to start (or a Tee to save clearance??), going straight up through the ceiling joists, a 45 degree elbow to center the flue between roof rafters and closer to the ridge line, then another 45 degree elbow to go straight up through the metal roof. I will be adding noncombustible material on the studs and a brick hearth for the stove to set on. This is a first time DIY for me. Can someone tell me if this makes sense to work and walk (crawl) me through materials, type of supports needed, flashing and anything else needed.
Thanks in advance for any and all help, Jeff
