So I fired my new (used) baby magnum up today for the first time, since it's the first time it's been cold. I'm using it in my garage, which is Uninsulated (I'll be getting around to that soon), so I wasn't holding out much hope for the garage to be toasty, but I figured I would see how the thing works.
Fired up fine, left it run for a few hours on the first setting, went back out to to check it, and it's got a big flame, convection fan is blowing, it appears all is working as it should, but there is nothing more than Luke warm heat being blown out of the thing. My Auburn in my house, even on the lowest setting blows hot air out (currently have my auburn on the lowest setting and my house is 75 degrees, it's 26 outside). So I'm a little confused as to why the magnum isn't throwing any heat. I turned the setting up to 3 and I will go check it again after a while, but does anyone know what could be causing this issue?
Thank you
Thank you
