So I am putting up some bamboo to dry. Never done it before, don't know anything about it, and it seemed like it'd be a bit of a shame to let all that wood rot.
Here's what I've learned so far:
Behold an afternoon's work. (Note that at least 75% of the time used was for chopping up roots with the pickaxe, and most of the rest was dragging leafy tops off into the woods. Actually cutting up the remaining canes was pretty fast.
Yeah, that ought to keep the house warm for a week in fall, or a day in winter.
I would say it was a waste of time, but I'd have been out there with the pickaxe eradicating bamboo either way, so I guess it's good that I got some kindling out of it.
- Bamboo is an absolute PITA to get rid of.
- Bamboo is mostly air. A cord of that stuff is not going to go far.
- Bamboo's segmented nature creates the potential for a glass-breaking explosion when a sealed chamber heats up and bursts.
- Relatedly, chopping a vent hole in your sticks every 8 or 12 inches is also a PITA after the first couple hundred times.
- You wouldn't think so to look at it, but you can in fact get a bamboo splinter and they are long pointy bastards and no fun to get under your fingernail.
- "Limbing" bamboo is best done with a sharp knife or machete. Fresh green stuff cleans up easily; dead brown stuff takes some hacking.
- Dropping a gnarly elm tree and processing it is easier than clearing bamboo and processing it. If you know elm, you know that these are strong words. At least you eventually get some decent firewood out of the elm, though.
- Chainsaws make terrible rototillers. Don't try it, even if your bamboo tempts you.
- It might seem like a great idea to flush cut the stalks and be done with it. Having actually ruined a stumping chain pursuing this theory, I can tell you that it's not a great idea. (How can you ruin a stumping chain, you ask? Isn't a stumping chain just a regular chain that was already ruined? Read on.) If you cut them as flush as possible the stabby little bastards will punish you every time you walk across the area. If you go into the dirt after all those little buggers, your stumping blade will quickly sieze up, grind down, and get little rocks in every joint. I actually threw a chain that was tightened correctly because several joints in the chain locked up hard.
- The best thing I found was to cut them about waist high so you can see them instead of stepping on them, then use a pickaxe to chop them off below ground level. This is even less fun than it sounds due to the root system being hard woody stuff that may require you to go around the perimeter with 3 or 6 whacks for one big cane.
- Lay out a long piece of rope and drop the bamboo onto the rope. Drag it so it's all sort of in the same direction, then use the rope to pull it and tie it into one big bundle. Then break out the saw and buck the whole bundle together.
- All the leafy branches are on the skinniest parts of the bamboo. Buck and keep the bottom parts, drag the top parts into a good spot for a bonfire and let them dry there. You can just dump them in the woods but it takes years for the canes to break down.
- It's a lot of work for a small amount of hollow firewood. Only recommended for those who are clearing bamboo anyway.
