fishingpol said:Nice work guys, you take sheds to the next level. I wish mine wasn't so full of stuff.
Thanks, well you could build another one.
I think this is exactly what I'm planning on, but am considering conduit. I'm also exploring options for running water, sewer and maybe even NG out there. My shed sits down a slope from the house, so I'm exploring macerators. If I start burying other things, then I need to figure out the codes for where they can sit in relation to each other.Don2222 said:Danno77 said:Can I get a quick summary on this?
You have a double pole 30amp in the main breaker box. Then ran 10-3 to a sub panel, where you have two 20amp breakers that feed into 12/2 wires. At that sub panel you have a grounding rod and the neutral feeds back to the main and the ground to the grounding rod. Sound right?
Yes that is correct. Also I dug the trench 2 - 3 feet deep but the electrical code is 18 inches, then at 12 inches I layed out the red warning ribbon in case someone digs there!
Danno77 said:Running 12-2 tonight. Loads of fun. Just picked up my christmas present of 2x4s from sis. These will be shelves in a couple of days for the workshop portion of the barn.
I'm not using that. Should I be? Not really sure what it is exactly! For grounding I thought I'd just be pig tailing the wires to the one post on the outlet.Don2222 said:BTW. Do you use the Green Grounding wires with screws and u shaped lug sold at Lowes?? I used 14 of them. Real Handy!
See 1st pic
Just wire to boxes right now. About 6 outlets and a light switch and ceiling light. My goal is to get the wire ran so that I can put the insulation in the walls. I am not running the electricity out to the shed until spring/summer because the ground is starting to freeze.Also what are you wiring tonight. I am interested since I am doing this stuff too!![]()
Danno77 said:I'm not using that. Should I be? Not really sure what it is exactly! For grounding I thought I'd just be pig tailing the wires to the one post on the outlet.Don2222 said:BTW. Do you use the Green Grounding wires with screws and u shaped lug sold at Lowes?? I used 14 of them. Real Handy!
See 1st pic
Danno77 said:Why do you have so many junction boxes?!?!
Yeah! Gotta have those staples. I've almost run out alreadyPopCrackleSnap said:Danno77 said:Why do you have so many junction boxes?!?!
And no staples? Or has the NEC changed?
Nancy
Nancy
That's the way mine have been, too!oldspark said:The outlets I buy have a grounding strap on the back of the outlet connected to the grounding screw so when you hook up to the ground screw the outlet is grounded, yours must not be that way correct?Well if you use metal boxes then those green wires make it easy to ground the outlet to the box
Highbeam said:Theory being that by grounding the outlet that the box is also grounded through the mounting screws, right? The other way I've seen is for the incoming ground wire to be looped around a screw in the metal box before landing on the outlet's green screw. I've never seen a separate ground wire added between the outlet and the box.
I just dug a 90 foot long, 2 foot deep trench, and set a 1.5" and a 1" conduit inside between the house and my new shed. The 1.5" conduit will hold the power line for the 60 amp subpanel and the 1" conduit will hold phone and cable. I've never buried empty conduit before so this will be a new one for me to fish wires through. I sure hope it works.
oldspark said:"Well if you use metal boxes then those green wires make it easy to ground the outlet to the box"
Fish On said:with all this work is there any zoning issues and what about your home owners insurance does not look like you will be bringing your lawn mower in there?
looks good though wish I had that much time on my hands.
Don2222 said:I hate trying to wrap 2 12 gauge ground wires on the small green ground screw they put on the 20 amp outlets!
oldspark said:Never had a problem bending a hook and getting #12 wire on the ground screw on the outlet.
