For me stack temp is the best. Unless you are using a cat stove then you need a cat probe. Stove top temps are slower to change that stack temp. So I use stack temp to run the stove
Here it's 3 newborns 3wks to 6mo. When their hands are cold we need heat. No ir gun here, stove top is for reference, flue temp is priority, outside temps in the 20s means maintaining a long slow simmer and watching the kiddos.
I just posted this note in another thread - for my Jotul F400, the manual is very specific about where on the top plate to put the magnetic thermometer. I suspect most stoves will have hotter and cooler spots, so you should measure in the same place. That said, I find comparing stove top and flue temperatures is very useful. I've installed some thermocouples connected to a datalogger recording stove temperatures. Flue temp are greater than stove top when stove is heating up. When stove is stable or cooling, stove top is hotter than flue, which I take to be a sign of good secondary burning.
