O
oldspark
Guest
Its time for the new chimney and need to move the summit out of the way, was thinking I am going to have make a frame work to jack it up I can move it, any one else delt with this?
oldspark said:Its time for the new chimney and need to move the summit out of the way, was thinking I am going to have make a frame work to jack it up I can move it, any one else delt with this?
BeGreen said:Summit, you are doing this for a living and may be able to lift 250lbs, but sure I recommend that, especially at over age 60 unless one wants to learn about hernias and popped discs quickly.
I am not 60 till the 20th of July so I'm all good. :lol:BeGreen said:Summit, you are doing this for a living and may be able to lift 250lbs, but sure I recommend that, especially at over age 60 unless one wants to learn about hernias and popped discs quickly.
Jags said:On the other hand - if your just moving it 6ft to the side - maybe a 2 x 12" to fit the bottom and a car floor jack is in order. Thats how I move the shop stove when needed.
BeGreen said:Jags said:On the other hand - if your just moving it 6ft to the side - maybe a 2 x 12" to fit the bottom and a car floor jack is in order. Thats how I move the shop stove when needed.
Make sure there is no ash pan if this method is chosen and watch out for the EBT. Personally I would have a few friends over, move it in about 30 seconds, then break out some brews in gratitude.
Friends? Now there is a problem!BeGreen said:Jags said:On the other hand - if your just moving it 6ft to the side - maybe a 2 x 12" to fit the bottom and a car floor jack is in order. Thats how I move the shop stove when needed.
Cool, I like, will look for them this week.BrotherBart said:Lift it an inch with a floor jack, put these suckers under the legs and move it wherever you want it. That is how I move the 30-NC.
http://www.sears.com/shc/s/p_10153_...21x00003a&ci_src=14110944&ci_sku=00926267000P
I get'em at the dollar store. And they worked great for the fridge too.
oldspark said:Cool, I like, will look for them this week.BrotherBart said:Lift it an inch with a floor jack, put these suckers under the legs and move it wherever you want it. That is how I move the 30-NC.
