I've read all the articles that were recommended to read before posting, plus I've been lurking in this forum for a while, but I still can't figure out what I need. My needs are not quite the same as it is for most people.
We plan to purchase a land (most likely with lots of live trees) early next year and build a small (1200 sqft) bungalow in it without a basement. It will be located north of Peterborough, Ontario (only slightly warmer than Minneapolis).
It will have a propane based central heating but we'd like to use wood as much as possible.
We are looking for a stove that works in the following criteria:
- Open space of roughly 500 sqft. This is living, dining and kitchen rooms combined. Ceiling will be 9ft if that matters.
- The house will have multiple large south facing windows with appropriate overhangs for cutting off summer sun. All insulation (inc. windows) will be above Ontario's required standards. I'm still debating how much money I want to spend into extra insulation beyond what's required.
- Much of the trees are softwood in this region. Although we will probably buy some high quality aged wood, we will probably try to burn as much of our own stuff possible. We expect that we will need to clean the chimney more frequently than usual. We will also plant trees that will eventually give us better firewood.
- Looking for a way to also transfer heat into other rooms of the house. I could build ducts within the insulated envelope and locate duct intake above the stove, but from what I have read, this approach works 50/50. In the worst case, we will use a small fan on the floor to manage the heat distribution.
I believe that poor quality wood doesn't work well in catalytic stoves so that may be out.
Given this, how much BTU do I need? Also, what type/brand stove would work best for me? We are expected to live in this house for 25+ years so we don't mind investing into some quality.
Thank you!
Thank you!
		 It gets overlooked because it is a "big" stove- but it turns way down and can burn a load for days with decent wood.
