I just removed a homemade monster of a wood stove from the basement of a new-to-me home. Ran the woodstove all last winter, but it was an all or nothing type of affair and horribly inefficient. I'm going to be putting a BK40 in its place.
The install is in the basement on a concrete floor, with plenty of clearance to any combustibles. The connection will be to a masonry(concrete block) clay lined chimney, 7"x10" clay liner (liner has been looked at and checks out fine; chimney is nice and clean). I have visually verified that the chimney has at least 2" to all combustibles where it passes through the house. The chimney is about 31 feet from the cleanout to the chimney top, and right around 27' from the existing 8" thimble in the masonry chimney to the top. With the ash drawer base on it, I don't have the minimum 2ft of vertical rise let alone the recommended 3ft. I have around 18" of vertical rise from the stove to the thimble.
My plan was to install a new thimble right around the 36" mark (plenty of room and clearance to do it.) and I wanted to run double wall 8" stove pipe from the BK to the thimble.
I've seen some threads that suggest with the taller chimney pulling more draft, the min. 2ft might not be as critical. Any logic to that?
Would it make the most sense to install a new 8" clay thimble and some type of adapter to accept DSP? Or is there some type of DSP insulated thimble that installs directly into the concrete block masonry chimney and gets sealed to the clay liner?
I'm also trying to consider how to make the installation the most flexible in the event that I need/want to install a liner at a later date. I don't want to have to reinvent the wheel and would want to utilize whatever I have for a thimble. If I had to do a liner, I'd be looking at a 6.5 x 9.4" oval liner to fit the existing flue and as closely match 8" pipe cross sectional area.
