I'll start! A really nice canvas wood carrying bag is a must have for moving wood into the house from the stand by stack outside.
			Don't we all hahaI want an arborist to drop off logs at house
Does the Dremel work good? I honestly never thought to use mine for this. Its basically for my wifes crafts. Any tips?Been sharpening my blades w/ a dremal lately, I'd like a battery dremal for when I'm away from the house cutting
I had a small Lopi installed last March. It replaced an older, radiant cast iron stove. The Lopi is more convective heat and I miss the radiant heat. So I might have said that I want a more radiant stove than a convective steel stove. I paid a lot for this new one and new chimney pipe so it's something I have to learn to live with. I have a small house but I can make it smaller by shutting off the bedroom and bathroom, mudroom etc. I can just sleep comfortably in the living room and be very warm but it's a compromise.Bigger isnt always better, but depends on the space you are heating. Some on here put in as much wood in one fire than I burn in a week, due to the bigger fire box. I just like small, low maintenance. If you can swing a bigger one, and keep up with the wood supply, Id go for it.
Same here, unless you consider an innertube for a failed log splitter tire. Black Friday is always spent either splitting wood or putting up outside lights, depending on which side of 30F the mercury is on this day.We've gotten off the consumer train and will be buying nothing this Black Friday.
But don’t all the articles say to just call the local tree services and have them drop wood for free?Don't we all haha
I have a tree service that drops wood for free here. He calls once or twice per year, asking to drop a load, and he would probably call more if I didn't turn him away most of the time. Sometimes I allow it, to help him out, but he knows it'd better be pretty nice stuff to even call me.But don’t all the arrivals say to just call the local tree services and have them drop wood for free?
Mine local guys must know they can turn a buck ‘cause they have wood stacks lining the property boundaries.
You have to buy the chainsaw sharpening round bits, found them at the big box store near the chainsaw blades. My luck has been very good, hold the dremal at 40 / 45 deg and you can do a 20" chain razor sharp in under 5 min,Does the Dremel work good? I honestly never thought to use mine for this. Its basically for my wifes crafts. Any tips?
 trilinksawchain.com
					trilinksawchain.com
				Check around with local tree removal companies and municipalities. You can get on a list and when in your area they will deliver! There are quite a few people on this site that get wood delivered.I want an arborist to drop off logs at house
Wouldn't a cordless drill work? Only issue I see is holding it at the correct angle. I have a cheap Dremel like rotary sharpener that clips to a 12v battery.You have to buy the chainsaw sharpening round bits, found them at the big box store near the chainsaw blades. My luck has been very good, hold the dremal at 40 / 45 deg and you can do a 20" chain razor sharp in under 5 min,
Some chatter online about the heat from the friction tempering the blade, I call hog wash, picked up the dremal idea after watching In the wood yard on youtube, that guy Chris only uses dremals for sharpening and he cuts north of 150 full cords a year.
A drill is to cumbersome, plus the rpm maybe to low, the dremal is long and narrow, way easier to hold at the correct angle, also I use full chisel chains, the back of the chain has a line engraved in it for the right angle so its easy to line the round head to the cutting tooth, I zip right thruWouldn't a cordless drill work? Only issue I see is holding it at the correct angle. I have a cheap Dremel like rotary sharpener that clips to a 12v battery.
