I purchased a Blaze King Princess in 2004. Best purchase we ever made. It worked flawlessly for seven or eight years. About three or four years ago we started noticing an occasional wood burning odor when we turned the stove down to low (say 1.5). We decided to replace the catalyst. We also replaced the door gasket which had never been replaced. This seemed to help some, but the following year we again noticed an annoying odor and even had the carbon monoxide alarm go off in the middle of the night. Pretty scary. The best we could tell the odor was coming from around the thermometer or chimney connector. I called Blaze King and they suggested that I might have inadequate draft (suddenly after 7 or 8 years). My chimney was eleven feet straight up from the stove floor. We decided to add four additional feet. Still on and off odor when we turned the stove down. Decided to check the bypass gasket. It didn't look in bad shape but the retainer was warped along the front edge. It had a dip of about 1/4 inch (maybe a little less) right in the center. Blaze King said I should be able to bang it straight with a ball-peen hammer. I banged and banged but couldn't budge it. I ordered a new retainer from Blaze King, but my local dealer laughed at me when I asked him to repair it, saying they don't do welding. I tried to find a local welder, but they all said they don't do house calls, they are afraid they would burn down my house. They said bring it in, but I can't bear hug an 800lb stove and throw it in my pick up!! Finally a friend used a torch to heat the metal and straightened (kind of...the best he could) the retainer. In went a new gasket ordered from BK. Still get the wonderful smell of smoldering wood throughout the house when we turn the stove down below half. BK doesn't believe the odor would be from a leaking bypass anyway because they said the gas should just go up the chimney, and at worst just cause extra creosote. We clean the chimney every year and never get more than a couple or three cups of soot. Have examined stove top to bottom. All gaskets pass dollar bill test.
Our stove has the outside air kit installed. Combustion air comes from under the house. I've looked up from the bottom and there is not so much as a cobweb that I can see. No problem with combustion. Burns good. We burn pine of varying age and dryness. Always have. It is the only wood available around here. Chimney is double wall pipe, fifteen feet from the bed of the stove to the top. Wind cap that turns with the wind direction. No tall trees within 100 yards of the house. Chimney stands about six feet above the roof of my one story home, and at least four feet above the highest point of the roof.
I am at a loss. Do I have to buy a new stove?
I wanted to switch to excel dw over the summer but somehow forgot to get it done.
