Hello everyone, I’m new to this and looking for some help/advice. I’ve read everything I can find on Blaze King stoves and it seems like I’m the only person having trouble controlling my stove. It’s uncontrollable. If I turn the thermostat up a hair the gauge on top pegs out pointing toward 5 or 6 o’clock. So I have been running it in low(I turn it down until I hear the little flap close) then I turn the dial up a hair and the gauge goes all the way up again forcing me to turn it back down. It’s driving me absolutely insane because this is our main heat source and I’m having to keep an eye on it 24/7. I’ve burned about 1 cord maybe a bit more through it so far.
I’ve talked to Blaze king and they were not able to provide any information to help. I spoke to the company I purchased the stove from and they said “this is a first” and couldn’t provide any help.
Stove - brand new stove, brand new chimney, 15’ straight up, double wall into class A through the ceiling and on the roof. Terminates 3’ above ridge.
Wood - all hard wood stored in my basement reading 12-14% on a fresh split. I would consider the splits to be medium in size. I’ve already tried loading with the largest logs I could find and it does the exact same thing.
I’ve tested the door gasket and it’s tight all the way around.
Relighting the fire while still in active zone. I disengage the cat damper, turn the thermostat to high, open the door, fill the box full, close the door, let it rip for like 5 minutes, close damper door and lock, start turning down the thermostat or it will climb to the 6 o’clock position on the gauge. I always turn it down when it points toward the word active on the gauge. I’ve tried turning it down slowly. It doesn’t help.
I have a call into our chimney guy to come out and add a 3’ section of pipe to the top to give me 18’ total. I’m at a loss of what to do so this is the last thing I can think of.
Please HELP!
