blazeking thermostat question.
ohiojoe13
390
alliance ohio
I have a ashford 30.1. When I run the stove on high (6 o'clock position) will the thermostat close before it over fires? Or does running it at that position over ride the closing of the flapper. The reason. I ask is because I have never seen the flames die down while running on high. But as soon as the adjust the dial the slightest bit down. I hear the click and the flames die down. Is there a way to test the thermostat?
It will closed enough to avoid over fire the stove but for what I understand it will not closed completely. After all at that point, we asking for high demand. Maybe somebody else have a better term to explain it but that is the way I think it works.
That's a good explanation. It won't shut the stove down because you are asking for maximum output. Max output is still regulated by the thermostat to prevent an overfire. Just make sure your bypass and gaskets are good.
If your door gasket and bypass gaskets are good (and both are closed), and you are using wood for fuel, the stove should not overfire on any thermostat setting including 100%.
