Block off bathroom vent in winter?
velvetfoot
10,202
Sand Lake, NY
Upon investigating a malfunctioning bathroom fan, I noticed a bit of incoming cold air . This bathroom is on the second floor .
There is no damper in the fan, which is, like, 12 years old. Maybe it was removed by the previous owner.
I found a similar new old sock unit on ebay for 35 bucks and hope to swap the guts out of the old one with the new, including the damper.
I read that for that vintage of damper, it is partially opened at neutral state for insulation on unit/fire code issue.
Besides, in my mind, in winter with house stack effect, there'd be more of a chance of heated air leaving the building envelope. The damper seems to protect cold air from entering the house, not the other way. Cold air wouldn't even be felt with he heated air leaving the house.
Anyway, I'm thinking of blocking it off during the winter. It's pretty dry in the house. Of course there's the stinky bathroom factor, which could make it a deal breaker for the wife, lol.
Any thoughts/ideas? I've never heard of a two way damper. I doubt I'd be able to reverse the damper. Maybe attach a coin to the damper flap?
I wouldn't, I'd swap it for one with a damper, plus there are exterior dampered louvered vent terminations you can install.
You need one of these, (broken link removed) Most houses are negative compared to the outdoors especially with wood stoves in winter. Standard dampers usually leak, these reportedly do not. Of course you still have the problem that if you seal up this air leak, if the house is negative its going to come in from somewhere else or you start to have issue with the stove not burning correctly and radon (if you are in area with underground radon.
An added note, if you ever take a bathroom fan apart you will find that its a very cheap device, not very well built to keep the cold air from coming back in.
Time to consider an air to air heat exchanger. It brings in outdoor air to balance the pressure difference between the outdoors and indoors. Super insulated homes seals up every air leak they can and then use an ex changer to carefully add air back in where you want to it to come in rather than the bathroom.
I wouldn't. If there's a shower being used in there, you might find it hard to keep paint on the walls.
Reactions: fespo
I wouldn't sweat a slightly ajar new damper.....what are we talking about here....<1 in^2 free section?
Your house probably has several hundred square inches of free section leakage all over the place...if it is 'tight'..otherwise it is thousands...you just can't feel the drafts they pull in or see them.
You have already spent way too much time thinking about those few square inches....go find some others to eliminate...I guarantee they exist.
Reactions: fespo and Ashful
You can certainly make it better but aiming for perfection is a waist of time and money. When you close one hole it just makes more comming from the remaining holes. It is also necessary for getting rid of extra moisture and contaminants from inside the house. The best thing I did for my house was to change all the doors and windows. I also installed new ceiling fans in the bathroom and outside evacuation dampers that close themselves when not in use. Humidity is around 40% inside the house all winter, no condensation in the windows unless it gets around 0 F
You know, believe it or not, I have an exterior dampered vent! So, I guess things aren't as bad as I thought! Duh.
Reactions: coutufr
Got the new fan. Could not put its damper in the old shell. Gave up. Put up everything else. Works fine. No trip to attic. I'll call it a success.
Reactions: woodgeek
There is a resonant vibration that pops up once in a while, so I'll have to address that.
Can you use a little piece of rubber to stop the noise? I keep an old tire tube around and cut off pieces for stuff like that.
Yeah. Maybe caulk as well. Have to disassemble and try to isolate. Doing other stuff around house as well.
Anyway, Happy New Year!
You too! It's a basement cleaning day here. I'm not really looking forward to leaving the house. Lol
