Blowers “chirping”
Ctwoodtick
2,303
Southeast CT; NW Maine
Blower on my wood insert started “chirping” like a bird chirping. What is the best way to fix that?
First you need to figure out where that chirp is coming from. Are the blades hitting the housing? Are they hitting a wire? Are they clean? Pet hair & dust can wrap around an axle & cause unusual sounds…
Thank you. I’d bet pet hair and dust. It’s on and off (currently off). If/when it starts up again, I will disconnect and blow them out with an air compressor.
I would guess it's the start of the bearings going bad in your blower fan. I had 2 P.E. fans go bad and that was the starting sign of the end. Definetly give yours a chance by cleaning it. Mine would chirp for a couple of months at least before stopping all together. It might be worth your time to start looking at what your replacement fan will cost. That's my experience with a chirping squirrel cage fan on a remote heat duct fan that ran 24/7 for entire heating seasons.
Occam`s Razor states the simplest answer is the most likely.
You hear a bird chirping in your blower and want the chirping to stop. Remove the bird.
(Or replace the blower/bearings)
