Blue Magic 18003 QuikSteel High Temperature Metal Repair
MishMouse
836
Verndale, MN
Does anyone have experience using this product to repair cracks in your wood stove?
My Harman TL300 is developing a crack in the metal at the top loading area.
I am wonder if this will be a good solution to fill the crack.
Right now the crack gets covered by the gasket in the top loading door.
I tried using JB Weld but since it can only handle up to 500::F, it was not a good solution.
According to the product it can handle up to 2,400::F
http://www.amazon.com/Blue-Magic-18003-QuikSteel-Temperature/dp/B0084AA2LK
That might be able to handle the heat but I doubt it would prevent the crack from getting worse in the future. Is that part steel or cast? If it's steel a stress relief hole should be drilled at the end of the crack, grind out the crack and weld it. I just dont see that stuff being a good long term solution.
