Bosca 700
How long have you waited? Several stoves take hours to shut down to prevent any possibility of smoldering pellets to smoke up ones home.
Seems that Bosca left the country and USSC may have parts for it. Owen lurks around here. I have little electrical knowledge and even worse on this short lived model line. Had many off the shelf components but controllers are make specific. Could be a bad triac?
Problem at shut down of stove combustion blower will not shut down,any thoughts Thanks
I'm going to PM you. as luck would have it we found a few parts for that unit so whatever it turns out to be we should have the part.
EDIT: let's do it in here so others who have issues can see.
1sthow long have you had the unit? when did this start happening?
2 thoughts on issue. The pressure switch is the reason, it is not opening back up. could be bad switch or the fan is not pulling enough to open it. If you are not seeing any issues with the burn, then the likely cause is faulty PS. Although in the end boards on the 700 could be an issue as well. Try by passing pressure switch (jump the wires) run it then shut it down. If it shuts down the normal way the PS needs to be changed and the board is not the issue. If it still has the same issue then it's a bad board. That's my thoughts and experience on that unit.
EDIT: Could be other reasons the fan can pull it open again, door gasket or other leakage in the system gasket on fan etc. So to start cheap check door/exhaust fan gasket. clean unit including the exhaust fan, then by pass PS, Then it's board. IMHO
I have a SOUL 700 Pellet Stove Insert and need gaskets for blower motors and would like new fire brick liner..any clues where we can get this stuff now?
You can try USSC. Might have them. On gaskets you can always use either a DIY "cut your own" gasket kit from an auto parts store, just a bead of RTV silicone.
Reactions: Owen1508
