It’s bloody cold here and would love to start using it. Please and help and advice would be amazing! Thanks for listening.
Thanks for the reply. I have read through it and followed the instructions but it only blows cold air and nothing is ignited. There are pellets present in the hopper, and unburnt pellets in the pot. The manual says to open the door to clean it but gives no indication to where the door is. It’s rather frustrating.First Have you read the manual?
If not do so it will tell you how to run the appliance.
The first thing to do is clean the stove as per the manual
If the owner left starting fluid it will not have an igniter
Does it have pellets in the hopper?
When you start it does it drop pellets into the burn pot?
I might suggest that you find someone with a pellet stove
to come and look at what you have anyone who has had a
pellet stove a few years should be able (after a little reading)
explain your stove and how it works
Good Luck
I’ll give the unit a great look over tonight. In my cursory look I could only see some screws holding the glass on. I’d really hope that’s not the door! Fingers crossed on the hidden latch.There has to be some kind of door in the front that opens to start
the fire and clean ash from the stove
You will not get heat until you get the pellets to ignite
So you have to be able to open the front of the unit somehow
Hidden latch?
I’ll give it another read tonight but even if there was I doubt I could find it. Thing looks like it’s not been cleaned in a whileMaybe there is supposed to be special tool with handle listed in the manual to open the door ??
I finally figured out the door! It had a couple of L latches on the door and you just had to pick up and remove the whole glass door. Kinda annoying but I got it!
I had a good read through the book, I do believe it doesn’t even have an ignition set up. It recommends a low volatile fuel for start up. Good luck on yours!with the bottle of ignitor fluid im betting the ignitor has went bad and they were lighting it with the fluid and a lighter.. Im doing the same this year since my ignitor went out and its such a pain to change out im waiting till i shut it down for the season before i change it.
