I just got a Breckwell Big E pellet stove and I'm ready to tie a chain to it and yank it out the wall. This was bought used at a local dealer shop and installed last Friday by a general contractor. It has 3" double wall pipe installed, comes out of the back of the stove with a 12" section of straight pipe to a 45 degree elbow, 12" section of straight pipe, though the outside (with thimble installed) to a clean-out tee, 3' straight pipe going up to a 90 degree elbow and then a cap at the end. All joints are sealed and some special sealant was placed at the back of the stove. It also has a fresh air vent hooked up with 2" flex pipe into 2" pvc pipe. From the first day of install, I haven't been able to use the stove properly. When I plug it in (to a GFCI surge protector) and press the on/off button, the stove will drop pellets into the basket and will light, but as soon as the blower comes on, the stove immediately shuts itself down and blinks on the "number 2" on the control panel. I have contacted the dealer where I got the pellet stove and they suggested trying another brand of pellets, which I have tried three different brands with no change. I have taken the stove apart five times and cleaned everything, replaced the door gasket (as suggested by the dealer), took off the sides to clean and it still won't run past the initial start-up. I have tried running it with the damper both closed and open and it still shuts off. I have no idea what could be causing this problem. Any advise is appreciated as I'm at my wits end with this thing.
