Breckwell P23i won't shut off...
CT Mets Fan
32
Watertown CT
After I hit the power button, the unit will start the shut down process, only hours after the fire is out, the blower fan is still going. I can stick my hand in completely cool coals, vacuum out the the chamber, and the fan stays on.
Anyone have any idea what is going on with this?
The unit still operates normally, pumping out heat as always.
Normal running setting is 2 out of 5, with 5 being the highest.
Stove can stay on for a few days consecutively before being shut down for cleaning.
Thanks
Hi mets- yes the convection blower is controlled by a snap disc mounted on the exh housing. Its a little ceramic style switch, should cost you about 30-40 bucks. Its pretty unique to Breckwell stoves I think, but should be easy to find.
