Buck slammer 30 years. Liner question
rox3406
Burning Hunk
Nov 5, 2017
109
New Jersey
Inherited my grandfathers house. Buck slammer for at least 30 years I know of. I know. Liner needed will do. Can't replace stove this year no funds primary heat source. Can I do a 6 inch liner with this buck. So I can buy a new stove next year or does she really need the 8 ?
Yes it needs 8"
And get ready for it to be a whole new animal to burn after the liner is installed. I put one on my 1985 slammer years ago and that puppy wanted to take off and run with the increased draft. Whole new learning curve.
Oh how my poor old back remembers doing that every year. <>
I so hate to replace her. She heated this house forever. But with a baby on the way I just can't run the slammer and sleep at night. This will be her last season then a new stove. I will give her a proper place in the shop as a free stander so she will live on
Random question. If I did an insulated 8. I have an external chimney could I slip a 6 inside of it at a later date? That would give me a few years left on the buck and more time to make a good decision on her replacement. Is that feasible?
Yes that would work fine
You might be able to run the 6" flue stove on the 8" insulated liner. Not ideal but within tolerance. How tall is the chimney?
That's the new plan. 8 inch insulated liner for now. Slip a 6 inside of it when I upgrade thanks.
I would try the new stove on the eight inch if it is a tall chimney. The stoves are designed and tested with 15-16 foot pipes. If you have a two story house and typical 20+ foot chimney the eight might just be the ticket for the new stove. Before I dinked around with air intakes my new stove on a 21' liner was like trying to throw a saddle on a running horse.
Reactions: begreen
That was my thought if this is a 2 story chimney. If there's room for a 6" to 8" increaser before the liner connection then it's worth a try it like that. Worst case scenario if the performance is suboptimal then you clean the 8" liner then drop a 6" liner down it.
I've got all the room in the world. I'm going to run the buck with an 8 till I get a new insert. Then thread a 6 into it. Thanks for the input
Thanks guys. That sounds like a good plan. I'll give it a try
I run a 28000 buck, I'm in Bedminster Somerset cty. Where are you?
I'm in New Jersey. Went with a 6 inch insulated liner. She runs awesome on it. I know the world says she needs an 8. But I can't get her to smoke inside. ripping fire doors open. Runs slow and low doors closed.
What town are you in?
