Oldman47
Small hatchet should be plenty. You are not trying to pry open the kerf. You are just preventing it from closing on the saw.
How do you guys pound your felling wedges in? Do you carry a tool or use a nearby limb? If a tool, what? I am curious. I own an Estwing Fireside Friend splitting hatchet but that dude weighs 4 lbs. I guess a regular hatchet wouldn't be heavy enough?
If I'm bucking a tree that's flat on the ground--especially if there's a lot of debris piled up and I don't have a clear view of the bottom edge--I'll bring my little 3-pound sledgehammer and pound the wedge in as hard as I can. That way I can see the cut opening up when the saw gets near the bottom and I can back out before I run the chain into the dirt.If you are sticking a wedge into a cut when bucking, I put it in with my hand and it just sits there but that's all you need to prevent jamming.
Hand 'stone' sledge hammer; never an axe; not much weight and easy to loose. The "Fly off the handle" kind of.How do you guys pound your felling wedges in? Do you carry a tool or use a nearby limb? If a tool, what? I am curious. I own an Estwing Fireside Friend splitting hatchet but that dude weighs 4 lbs. I guess a regular hatchet wouldn't be heavy enough?
This looked to be the case right away to me - cut from right to left, the trunk should remain off the ground through out the whole process - what a back saver!I should clarify that the tree's actually not under any tension other than what's caused by its dead weight
I don't have a floor jack but the thought had occurred to me that something like that might come in handy. The tree ironically fell across an old logging road but unfortunately it's not easily accessible, so I pretty much have to schlep everything in & out manually.This looked to be the case right away to me - cut from right to left, the trunk should remain off the ground through out the whole process - what a back saver!
I have taken in a 3 ton floor jack before to jack the tree up by the root ball to keep the trunk off the ground and keep from bar pinching. Not sure if you can get one back there, I toss mine in the back of my Polaris.
TwinsburgWhere in NE Ohio are you, @TedyOH ? I was born & raised in Youngstown...
![[Hearth.com] Bucking Advice? [Hearth.com] Bucking Advice?](https://www.hearth.com/talk/data/attachments/178/178388-515a131134c0b7ca05f10ce41e75dd4f.jpg?hash=tFEhsad0r9)
Not to resurrect an old thread but I wanted to give you credit for calling this one--I noticed recently that after 4+ months the root ball hasn't come an inch closer to "standing back up." The trunk also floated while I was cutting it, which made life much easier. Good call!I've never had a tree that was parallel to the ground "stand back up". I've had them float and bounce up and down.
