Built in wood burning fireplace advice please
soontobethree
3
Ontario
We are building a 1500 sq ft home. Looking for recommendations on a built in, wood burning fireplace, that has the largest viewing area possible. We will have a propane furnace, the fireplace will not be the primary source of heat. We were looking at the Ambiance Elegance line but I've just read a few reviews of people not being happy with the heat that it produces. Thanks for any guidance provided.
One needs to be careful not to oversize the fireplace for the space. There are some very large ZC fireplaces with huge viewing windows, but they could overheat the home quickly.
How large is the area that the fireplace will be located in? Is this an open floorplan or is the fireplace room only connected by doorways and halls? What is the budget for this fireplace and installation?
Thanks so much for your invaluable response! We definitely don't want to overheat the home but really want to see as much of the fire as possible when we have one going. The area that the fireplace will be located in is an open floorplan space that is approximately 650 sq feet. It will be on a wall that is 18 feet wide. Our budget for the fireplace and installation is between $10 - 12,000.
If the fireplace will at some times be running 24/7 for heat, for example during an extended power outage, then a modern, high-efficiency fireplace is best. There are cheaper, contractor grade units, but they are mostly for the fire show.
For size, compare models in the 2.0-2.5 cu ft range. The Canadian made, Valcourt Lafayette II and PE FP25 are a good place to start. RSF also makes units in this size range.
