Wonder what everyone means by burn time I put wood in my burner throughout the day but what does it mean
With the princess I am using I pretty much always load at 8 or 12 hours very occasionally 24. There certainly are times that is early and I could get longer but my loading schedule also needs to be at times that make sense with my sleep/work schedule. I load the stove full each time. The number of logs will vary greatly depending upon size and ammout of ash or coals that is in the fireboxSo your saying 12 hours how many logs you putting in I put three maple logs in about every 2-3 hours what am I doing wrong
www.hearth.com
www.hearth.com
Does it have a full 6" liner running from the stove out the top of the chimney?It is measured in three locations all are under 20 % what do you mean flue height from the insert to the top of chimney it is about 20 feet it was installed in an existing fireplace does that make sense
Sounds like this is the insert, correct? The flue height is good. Is the stove being loaded E/W, N/S, or criss-crossed? How thick are the splits? It seems like the firebox should handle about six 4" splits.I am burning a enerzone 1.8 solution stove I can fit about 4 logs
Liner insulation requirements depend upon clearances from the outside of the chimneys masonry structure and combustibles. From a safety standpoint it's more important on internal chimneysOn an interior chimney it seems to be okay to run with an uninsulated liner. For exterior wall chimneys you need the insulation to avoid heat loss.
My firebox is a similar size (10% bigger) - if you've only got 4 logs in there, they might be too big for the coal bed. I can load some nice big rounds in mine where only 4 will fit, but the whole stove needs to be nice and hot with good coals for that to work. Otherwise, I have better luck with a mix of smaller rounds and splits, with maybe 5 - 7 logs. I've been doing 4 reloads per day when the high is below 20, 3 when the high is below 40, and 2 otherwise - it's a soapstone stove, so how long of a useful burn time depends a lot on whether the stove is already hot (it takes about 40,000 BTUs to heat it up by 200 degrees - that then gets released as it cools, which is great for overnights, but the morning fire is definitely a bit shorter to get everything back up to temp).I am burning a enerzone 1.8 solution stove I can fit about 4 logs and if I put damper all the way in it just smoldering and the blower shuts down not producing enough heat moisture content is tested and it well within standards I just seem to be loading wood to frequent
You're right. The Enerzone 1.8 has the same firebox as the old Drolet 1800i. The Escape 1800i grew a full firebrick deeper. Not sure why they didn't rename it the Escape 2400i.My 1800i has a 2.4 cu ft box. But my other stove is 1.7. Yeah I’ve loaded 4 splits and it was full. Heck I’ve put just two in and didn’t have room for anything else. You get better and judging what splits will fit together and playing Tetris.
Your draft might be to strong, sending most of the heat up the flue rather then letting it radiate out the stove top.Yeah that's one thing I've been disapointed in, the PR version of burn time vs reality. VC claims 14hrs for my Defiant, that's laughably inaccurate. Granted I'm a rookie at loading the thing but if I fill it to the gills I'll get about 4hrs from flipping the cat on (30 minutes after loading on a hot bed of coals) to when meaningful heat is gone which to me is dipping down to 300 F. Maybe tack on 1 extra hr if we're talking till coals no longer glow. Still a far cry from 14, they must have some ultra dense magic wood or something.
How would one go about fixing that?Your draft might be to strong, sending most of the heat up the flue rather then letting it radiate out the stove top.
