Don't have a lot of it around me but 20 miles either way of me it can be all over the place. Going to try to source some of it somewhere but like to know what I'm getting into before I try scrounging any of it up. An info on this welcomed.
I have laminated Beech countertop (Ikea) in two properties and wears extremely well. Much better than the birch I have in one property that has just rotted away over the years.Great wood, all it's good for is firewood. Makes real fluffy ashes and it's clean wood with slick clean bark.
What a waste... Maybe they'll have a logger come in for timber or veneer?Thanks all for the replies! There's a few parks to the east of me (50 miles) that have some old growth Beech 4' DBH and 100' plus tall that were downed from recent storms. These had to be 200+ year old trees. All I could think of is the amount of firewood locked up in those trees that will just go to rot as they would not be allowed to be taken (Baltimore City park property). Was thinking I got to try some somewhere.
I know, I get it. It just seems so wasteful.The rational for not allowing wood cut on public land to be sold (or given away) is not that uncommon. The theory is that if there was an economic incentive for cutting trees that some public employee would be managing the trees for economic reasons versus looking out for the best interest of the woods long term health. I also think in general it is probably a PITA for some government entity to actually sell the wood and follow government guidelines. As for giving it away, image all the poorly equipped poorly trained folks showing up to get their share of the wood.
If you can get some, don't pass it up, it's great firewood. When I first started cutting, we had two years worth of cherry c/s/s from a bad wind event that hit this area. I ended up getting a load of beech logs so we would have higher btu wood for the colder months, it was well worth the money back then.Don't have a lot of it around me but 20 miles either way of me it can be all over the place. Going to try to source some of it somewhere but like to know what I'm getting into before I try scrounging any of it up. An info on this welcomed.
You seem to know a lot about beech. When you talk about blight do you mean beech blight aphids? The reason I ask is because I have a copper beech yard tree (planted in a stupid location 38 years ago) that was VERY slow to leaf out this past spring. After it finally leafed out it had what looked like a cottony substance all over the leaves. I did some research and it turned out they were beech blight aphids. Upon close inspection I could see them in picture close ups. This fall the tree dropped the leaves much earlier than normal. It usually slowly releases them all winter, but this year they were all gone by late November or early December. It was also COVERED in ladybug larvae at one point. I've been wondering if I'll be dropping it in the near future.Beech is great firewood, especially up north where the oaks do not grow. My experience is it takes 2 years to dry well. Beeches can grow tall and straight in the main stem but many tend to have a lot of kinks and bends in their branches especially in the crowns. Cutting up the crowns takes time as the branches are rarely straight. I only cut beech with the leaves down as dealing with the brush is a major PITA as it does not lay flat and ends up taking a lot of space. It's a bit less hard to handle with the leaves off. One hint is wear eye protection when working with it as there are always random branches sticking up ready to poke an eye. Because of the kinks and bends, there usually are more "uglies", crotches and bent pieces as a percentage of the straight wood so plan to have a way of managing the uglies as they do not stack well and if someone is into a stuffing a woodstove tight, the odd twists can be annoying. I burn the uglies in shoulder season.
The main stem of the tree is usually straight grain and I flat split it with my splitter so I end up with flat "boards". I use them to build up the ends of my wood piles like legos. If I do it right, the ends stay upright with no need for end poles or boards.
There are a couple of non native diseases attacking beeches these days, the beech blight is attacking the bark up north and heading south and there is new disease from down south heading north attacking the leaves. The beeches with blight, have scars and pock marks in the bark. There is some resistance to the blight so some trees remain somewhat healthy but a lot of them will die from it as the scars and pock marks will turn into rot and rot the tree from the inside out. If possible, if you see beeches in a stand that appear resistant to the blight leave them standing.
Those pock marks and holes in the otherwise smooth bark means that when blighted beech is on the ground and to lesser extent in the stacks, it going to hold a bit more water and rot quicker. I cut and buck mine in the winter on top of the snow and then get it split asap in the spring and get it stacked with top cover over the stacks. If it has been sitting on the ground in log length for several months I usually will leave it as the rot will move in quick.
I have about 60 acres with a lot of blighted beech, way too much for firewood, so the small stuff will get dropped in place, with the cut stump painted with Garlon (a herbicide to kill off the roots). The big trees will be girdled, with the saw cuts painted with Garlon and then left to rot standing. That will eventually encourage other species like sugar maples to take over and shade out the beeches. Beech clone themselves from old roots and cut stumps readily so they can move in quick after a logging cut or natural disturbance and take over a stand. If the old root came from a tree with the blight, the new clones will inevitably have the blight and grow up into stunted stands.
![[Hearth.com] Burning characteristics of Beech? [Hearth.com] Burning characteristics of Beech?](https://www.hearth.com/talk/data/attachments/323/323137-e1008851d8f88734e3a6d6c63cd435e9.jpg?hash=mLuvXgJcgJ)
an excellent descriptor for beech bark...I was thinking the same when trying to describe beech barkMy wife says it looks like a giant elephant leg.
