- Jan 5, 2013
- 247
Just teasing with you ~ glad the blend is working out for you
I have tried the northeast from TSC. Not sure if I liked them. Less flyaway ash than the MWP blend. I feel about the same or a little better for heat. The Northeast was a softwood blend 80/20. Definitely not as dense as the MWP. Dialed in a little more on the feed for medium to get more heat. MWP is all I've bought this year other than a few bags of this or that to try. Going to have a night or two in the single digits here in CT. Wondering how medium will hold up.i know.: )
burning the softies since last night.
seems like i need to increase the feed rate for them.
flame height definitely lowered with them burning.
still unsure of exactly how to evaluate them.
i mean, i know they are good. just need to get the stove dialed in for them.
might switch over full time next year. but only if the price is right.
pretty sure fewer pellets are being delivered per cycle with the softies.
still had a least the same heat. maybe a little better. but it's apples and orange till i get the feed dialed in.
How did the up the feed rate on medium work for you?i know.: )
Sorry for what? Nothing to be sorry for. It's my first year and I'm working out the kinks. Right now have my feed open almost all the way on medium. Once my hopper gets down then I'll adjust my feed and run on high. Running on high now with the feed setting, WAY too much. Flame really high. Dont want to have an overfire. Supposed to be in the single digits for a few nights and I don't think medium even with the feed open almost the whole way will keep up, despite the and currently peaking 5-7 inches above the pot. Spikey like we like. Not lazy. Only have MWP hw blend.switched over to the mwp softwoods. so far i have the gate all the way open. running low when it's warmer outside.(yesterday in the low 30s) and on medium with some high as it gets below zero.
lol. sorry to change the parameters.
At this point in my Life, I am done "Settling" for something. If its not what I want, I am not gonna get it.. I either wait or go elsewhere.
So far so good with the current setting but only in low 20's right now. 72 in the house right now. Drops min of 2 degrees at night on medium. Might leave it this way till morning then adjust and run on high with feed closed. I empty the pot once daily. I don't worry about that.just kidding about the sorry.
yeah open it up for the cold. just don't want the pot to get clogged w/ too many pellets.
Hey dexterday. Probably a stupid question that's been asked before but after reading the manual again I had to ask. The flame height, got the numbers. But is it 4-8 steady or when it peaks? Because my hi will peak 10 + alot. I don't if this is normal. It's only peaking very tall and I'm not sure if that's normal. Even after firepot emptied and cleaned it is the same. Feed gate is closed as far as you can.Its built just like a Quad mac. No High/Low on them. Thats the only thing I dislike about my Quad. Heat output is AMAZING, just wish it wasn't On/Off only.
I agree 100% about the pellets. Cost is cost. Your gonna have to buy more oil or buy more pellets?
As for the Heatilators, they use Quad components, the airflow through the Heatilators pot is reduced, and they dont have the same heat exchange system as a Quad. Its similar to the CPM in heat exchange regards.
Using the same type of pot and blowers, the burn should be the same. But there flames are not as active and are a skinnier, taller flame (Quad says 4"-6" for High--- Heatilator says 4"-8" for High).
Has anyone here posted a video on the Heatilator flame? This may help several different individuals right now? There are a number of people struggling with the stove and its performance. Most issues are likely not because of the stove.
A short 2 minute video for a low flame, then another for medium flame, and finally High setting..
I have a couple for my Classic Bay, one on the CPM, and my Fahrenheit. Videos help others to better understand? IMO
