Check out your BTU ratings. Most stoves are rated as 'maximum BTU' but the real world usable BTU is usually 40-50% less. A furnace in an average house in our area is 75,000 BTU, so 90K is A LOT.30000 BTUs? That wont work for me ,i need 3 times that on a cold day.
max on the stone cladding, so you really do need a huge surface area to generate enough BTUs. I know my VC is worthless if I burn it at 400 and wonderful at 700, so 150 is a big leap for me. I saw one masonry heater in northern Italy when I was there a year ago. I didn't even recognize it at the time. It was warm to the touch and that's it. Sure made the room nice though.Guess I was wrong about the fiberglass. Guess it makes sense though, R stands for resistance, not exclusion.
Masonry heaters can vary with the shell temps, based on design.
But yeah, they take a lot more surface area than a similar output iron/steel stove. The shell materials can affect that rate of transfer too. That's why you see a big difference in designs based on application/materials. And lots of heated benches/chairs, sleeping quarters. If you have stone on your property, it could probably be designed in and trade $ for sweat. But the type of stone is important as different stones have vastly different heat retention and transmission properties.
Thanks for the info. Unfortunately life got too busy to make the build you told me about. But I'll eventually get to one of the events.
![[Hearth.com] ByQ masonry heater? [Hearth.com] ByQ masonry heater?](https://www.hearth.com/talk/data/attachments/129/129961-c1141d34057ec20fd35c8ddb58929a3f.jpg?hash=QkUNbTgAa-)
![[Hearth.com] ByQ masonry heater? [Hearth.com] ByQ masonry heater?](https://www.hearth.com/talk/data/attachments/130/130064-ae25979b4600704328c0e4fbfeef3715.jpg?hash=MgeqI2kUMO)
Don't forget that the outer shell has to be a self supporting wall. My feeling is that the 2" pieces are too thin and will not hold the weight of the ones above them when they are that large without wanting to buckle. I'm guessing you're going 8' or higher. Backfill with mortar is not that strong and the thin mortar will want to crumble and then you've got a real problem. I'd prefer to use 3 or 4" pieces. Just my thoughts and I'm not a mason but you may need a mortician.![]()
![[Hearth.com] ByQ masonry heater? [Hearth.com] ByQ masonry heater?](https://www.hearth.com/talk/data/attachments/130/130074-420c3cac9d638142f48f599f9da9a8d1.jpg?hash=-4nT6v_NYU)
Take a sledge and break up the ones that are too heavy to load. If they're that heavy, you won't be able to work with them when you are on scaffolding 5' up. The other option is to use 2 thinner pieces mortared together. Not sure if I would recommend it ... but.
Yeah. The more I read the more I like them. Especially when it comes to 'user friendly'. Only needing your attention a couple times a day is hard to beat without electricity.I'm going to start watching this thread. Kinda interesting stuff these Masonry Heaters.
![[Hearth.com] ByQ masonry heater? [Hearth.com] ByQ masonry heater?](https://www.hearth.com/talk/data/attachments/130/130323-0edf79e9bb254c63570c597b4ddaed52.jpg?hash=KIWjqutm8W)
