I have a Heatilator CAB50 that worked fine until the spring. On startup this season the unit starts normally, feeds pellets, ignition, a decent fire, convection blower starts and the unit seems fine until this point. Once it has been running for a few minutes, pellets continue to drop but it seems at a reduced rate. The fire of course dies down but the unit continues to drop some pellets but not what I would consider to be the normal amount. If I hit the reset button on the rear of the unit, it drops pellets like it would on startup and shortly after the entire cycle repeats. I have cleaned this unit as per the manual, removing the baffle plates in the fire box, the exhaust vent, the firebox itself, have removed both side covers and vacuumed the interior of the cabinet, blew the pressure hose out, removed the stack and clean that (there was very little residue there), emptied the hopper and cleaned and vacuumed it, etc.
My first thought was a weak auger motor but it does feed properly on startup and if I hit the reset button. I am open to any thoughts as to what the issue may be.
![[Hearth.com] CAB50 Pellet feed issues [Hearth.com] CAB50 Pellet feed issues](https://www.hearth.com/talk/data/attachments/285/285791-bc8be1733d4aee0cf728b11ff5a350a9.jpg?hash=JJbuVvQJ7H)
![[Hearth.com] CAB50 Pellet feed issues [Hearth.com] CAB50 Pellet feed issues](https://www.hearth.com/talk/data/attachments/285/285790-2e29aba56ce71a8245c78307fe5d0493.jpg?hash=5Fsa56z-hL)
![[Hearth.com] CAB50 Pellet feed issues [Hearth.com] CAB50 Pellet feed issues](https://www.hearth.com/talk/data/attachments/285/285789-a4d6accf660a92aed88d8dfb92f8fa22.jpg?hash=5dtPSQxtR7)
![[Hearth.com] CAB50 Pellet feed issues [Hearth.com] CAB50 Pellet feed issues](https://www.hearth.com/talk/data/attachments/285/285870-315fdabe6e3b69bf0b73a61141aafe00.jpg?hash=x5zz76y6mj)
