I know a guy...I do however would like to make a damper controller to run off of flue temps...but I always get lost in the threads.
I tried to get it working on my Caddy but I couldn't figure out the logic on getting the timer, relay, and thermostat to all play together nicely. @brenndatomu even sent me one of his high quality drawings and I still had problems.I do however would like to make a damper controller to run off of flue temps...but I always get lost in the threads.
One of these days we'll have to get you to come down past Route 30 and help us out.I know a guy...![]()
From what I gather, the guys that have the newer SBI made furnaces all say they almost never come off speed 1...
Well I confirm that its running on speed 1 almost all the time... its hard to heat the house fast that way.....
Your house may be different but faster blower speeds does not always equal better heating. In our case, it was actually the other way around. YMMV
So i prefer that way ! Ok ok but in my case when I get it to higher speed... its heat up the house fasterSo i prefer that way !
My house is 2 story and is 24x30.... the du ts were built when they installed the furnacd...
I was told, you can test the blower speed by heating up the rtd probe with a lighter !!??? I tried but it didn't change the blower speed !! I made it running on speed 6 when it "overheat'' with the lighter..... If anybody has the same furnace... can you try it ?? Thanks !
So it did change...or it did not?I tried but it didn't change the blower speed !! I made it running on speed 6 when it "overheat'' with the lighter.....
It did only change to speed 6 when overheated !So it did change...or it did not?
How many speeds are there? The Drolet products only have 4It did only change to speed 6 when overheated !
What size of house are you trying to heat? Duct sizes?
2 story house 24x30
Furnace air intake location?
The furnace is in the basement... there are air intake on each floors and the 1st has even 2 air intakes
Wood quality and moisture content?
Ash tree around 10 % moisture
Are you getting secondary combustion?
Yes
How far away is your thermostat from the stove?
The thermostat is on the first floor away from any heating and sunlight
What is your plenum temp?
It always depends how long the damper stay on... but let's say around 70-80 degree celcious
Would you be willing to put a tempurature controller and speed controller on your stove?
Eventually if not able so solve the problem !
Have you called PSG and asked for their advice on how to troubleshoot your problem ? To me, it sounds like the temperature probe is either not working correctly or was not setup correctly.
Is this a new problem or has the furnace always stayed on speed one ?
If your plenum is at 70-80 celcius with damper open your fan speed should definitely be kicking up a few speeds.
Go to your board under the troubleshoot setting and test your fan speeds manually. You should be able to try every fanspeed.
On my tundra I'm able to hold down +and- for about 3 seconds to access the low end menu of fan speeds 1-4.
The menu is only able to test each fanspeed. It won't stay on the selected setting indefinitely.
Yes I tested all the fan speeds... they all work fine !!
